How to edit disabled function at Directadmin and Cloudlinux?
Issue:
You are using DirectAdmin with CloudLinux, and the exec() function is disabled in PHP 7.3. When you check your [phpinfo()] output, you see `exec` listed under disable_functions.
You want to enable the `exec` function.
Environment:
  • Control Panel: DirectAdmin
  • OS: CloudLinux (with CageFS)
  • PHP Version: alt-php 7.3 (via PHP Selector)
Solution:
1. Connect via SSH as root:
ssh root@your-server-ip
2. Find the correct config file that sets disable_functions:
grep -r "disable_functions" /opt/alt/php73/
Look for an output like:
/opt/alt/php73/etc/php.ini:disable_functions = exec,system,passthru,shell_exec,...
3. Edit the php.ini file:
nano /opt/alt/php73/etc/php.ini
Find this line:
Remove `exec` from the list:
disable_functions = system,passthru,shell_exec,...
Save and exit (`CTRL + X`, then `Y`, then `ENTER`).
4. Refresh CageFS and restart PHP:
cagefsctl --force-update
cagefsctl --remount-all
systemctl restart alt-php-fpm73
Alternative command if the one above fails:
service php-fpm73 restart
5. Verify with phpinfo():
Create a file called `phpinfo.php` in your website’s public_html folder:
PHP:
<?php phpinfo(); ?>
Open it in the browser and check the “disable_functions” section. `exec` should no longer appear there.
Notes:
- This method works only for alt-php versions managed by CloudLinux PHP Selector.
- If you're using a `.user.ini` or custom `php.ini` per user/domain, check those files as well:
find /home -name "php.ini"
find /home -name ".user.ini"
