What's new
Welcome to the forum 👋, Guest
To access the forum content and all our services, you must register or log in to the forum. Becoming a member of the forum is completely free.
Installing and activation Phalcon 3.4.5 to Cloudlinux and Directadmin
aior
aior
Below is a step-by-step guide for installing Phalcon 3.4.5 from source and activating it under CloudLinux + DirectAdmin on PHP 7.3. Because CloudLinux does not ship Phalcon 3.4.5 by default, we’ll compile our own .so and then enable it via CloudLinux PHP Selector. Finally, we’ll show how to enable the extension specifically for a user (e.g., sikayetler), which is sometimes necessary when different users need different modules.
1. Have PHP 7.3 installed via CloudLinux (e.g., alt-php73).​
2. Install the devel package for alt-php73 if not already installed:​
yum install alt-php73-devel
3. Have development tools (e.g., gcc, make) on the system. If not:​
yum groupinstall "Development Tools"
4. Download and Compile Phalcon 3.4.5
1. Go to a build directory:
cd /usr/local/src
5. Clone the Phalcon 3.4.5 repo (or download the tarball):​
git clone -b v3.4.5 --depth=1 https://github.com/phalcon/cphalcon.git
6. Enter the relevant subdirectory (often build/php7/64bits for Phalcon 3.x):​
cd cphalcon/build/php7/64bits
7. Use CloudLinux’s alt-php7.3 phpize:​
/opt/alt/php73/usr/bin/phpize
8. Configure pointing to the correct php-config:​
./configure --with-php-config=/opt/alt/php73/usr/bin/php-config
9. Compile:​
make
10. Copy the resulting .so to the alt-php73 modules directory:​
cp -rp modules/*.so /opt/alt/php73/usr/lib64/php/modules/phalcon.so
11. Create the INI File
CloudLinux recommends placing custom extension config files in:
/opt/alt/php73/etc/php.d.all/
So create (or edit) the phalcon.ini there:
nano /opt/alt/php73/etc/php.d.all/phalcon.ini
Inside, just put:
extension=phalcon.so
Save and exit.
12. Make Sure the Domain Uses alt-php73
If your domain (e.g., sikayetlerim.com, emlakservisi.com) is not truly on alt-php73, it won’t see the extension. In DirectAdmin:
1. Go to Domain Setup (or “PHP Selector” in the user’s control panel).
2. Select PHP 7.3 (alt-php73) for that domain.
3. If there’s a .htaccess with AddHandler … php82, remove it or change to php73.
13. The most important step --> Activate Phalcon for a Specific User 👏
If you don’t enable it globally, or you want to selectively enable it for certain users, use:
selectorctl -u USERNAME -v 7.3 -e phalcon
For example, for user sikayetler:
selectorctl -u sikayetler -v 7.3 -e phalcon
Then confirm with:
selectorctl -u sikayetler -v 7.3 -g | grep phalcon
You should see phalcon listed, meaning it’s enabled for that user.
14. Final Check: phpinfo()
Create a phpinfo.php in the user’s document root:
<?php
phpinfo();
15. Load it in a browser:​
• Confirm:
1. PHP Version 7.3.x … alt-php73
2. Phalcon shows up under the extension list.
If you see Phalcon 3.4.5 in phpinfo(), you’re all set!
Theme customization system
You can customize some areas of the forum theme from this menu
Choose the color that reflects your taste
Wide/Narrow view
You can control a structure that you can use to use your theme wide or narrow.
Grid view forum list
You can control the layout of the forum list in a grid or ordinary listing style structure.
Picture grid mode
In the grid forum list, you can control the structure where you can open/close images.
Close sidebar
You can get rid of the crowded view in the forum by closing the sidebar.
Fixed sidebar
You can make it more useful and easier to access by pinning the sidebar.
Corner radius close
You can use the radius at the corners of the blocks according to your taste by closing/opening it.
