1. Once you're connected to your server with SSH root user, navigate to the CustomBuild directory. By default, it's usually in the `/usr/local/directadmin/custombuild` directory. You can get there with the `cd` command:
2.Then, update all software with the code below.
Warning!: It will take serious time to update all and never disturb the process. Like 15+ minutes)
Also please try not to make updates at live web pages. Propably you will get error messages or you may get problems without warning message.
Here is the results:
After that you will not see any mode update alarm without update button at Directadmin.
cd /usr/local/directadmin/custombuild
./build all d
