ElasticSearch installation for AlmaLinux
Thread owner
I have been trying to install Elasticsearch for Xenforo for a while. I was getting some problems which is not clear for me. Finally, I achieved to install and run elasticsearch and want to share the steps with you:
First connect your server as:
yum update -y
root and update your system:
Update your structure and packages with codes below:
sudo dnf update -y
sudo dnf clean all
Remove previous installation with code below:
yum remove elasticsearch
Remove previous Java installation
yum remove java
Type y and press enter.
Then you are ready to make fresh installation.
Go to home if you are not with:
cd
Install elastic search:
sudo yum -y install java-1.8.0-openjdk java-1.8.0-openjdk-devel
install nano if you do not have nano and accept:
yum install nano
Then set Java_Home settings:
First oppen the file with:
nano /etc/profile.d/java8.sh
Then add the codes to file with right click of mause:
export JAVA_HOME=/usr/lib/jvm/jre-openjdk
export PATH=\$PATH:\$JAVA_HOME/bin
export CLASSPATH=.:\$JAVA_HOME/jre/lib:\$JAVA_HOME/lib:\$JAVA_HOME/lib/tools.jar
Then press Ctrl + X on windows and press y + Enter
Output will be like:
Check your java version with code:
java -version
Source the created file with code:
source /etc/profile.d/java8.sh
Thread owner
Now we are ready to install Elasticsearch to Almalinux
sudo rpm --import https://artifacts.elastic.co/GPG-KEY-elasticsearch
Use Nano again to edit the file with code:
nano /etc/yum.repos.d/elasticsearch.repo
Change the file with the codes below:
[elasticsearch]
name=Elastic repository for 8.x packages
baseurl=https://artifacts.elastic.co/packages/8.x/yum
gpgcheck=1
gpgkey=https://artifacts.elastic.co/GPG-KEY-elasticsearch
enabled=1
autorefresh=1
type=rpm-md
Output must be like below:
Then prepare installation
sudo yum clean all
sudo yum makecache
Then complate installation:
sudo dnf install --enablerepo=elasticsearch elasticsearch
After installation you can check the installation status with:
rpm -qi elasticsearch
Output should look like below:
Then configure elastic search with nano:
nano /etc/elasticsearch/elasticsearch.yml
and be sure that you have the options as below:
cluster.name: mycluster
node.name: node-1
path.data: /var/lib/elasticsearch
network.host: 127.0.0.1
Start elasticsearch on everyboot :
sudo systemctl enable elasticsearch
sudo systemctl start elasticsearch
Check if elastic search is running or not:
systemctl status elasticsearch.service
You can leave the screen with Ctrl + C combination.
If you want to use elasticsearch at xenforo here is the next steps.
Go to Xenforo Admin Panel Setup --> Enhanced Search
Toggle advenced options and type your password. Username is elastic; to see the passwords type the code below:
cd /usr/share/elasticsearch/
sudo bin/elasticsearch-setup-passwords auto
You will get several passwords and users just choose elastic user and copy the password and type the password to Xenforo:
Finally, you will be able to connect Elasticsearch and results will be like:
Enjoy your Elastic Search
Please write for any question.
Thread owner
When you install elastic search note the output below for resetting elastic user:
--------------------------- Security autoconfiguration information ------------------------------
Authentication and authorization are enabled.
TLS for the transport and HTTP layers is enabled and configured.
The generated password for the elastic built-in superuser is : OaReYd2lERsl06e8o+Gw
If this node should join an existing cluster, you can reconfigure this with
'/usr/share/elasticsearch/bin/elasticsearch-reconfigure-node --enrollment-token <token-here>'
after creating an enrollment token on your existing cluster.
You can complete the following actions at any time:
Reset the password of the elastic built-in superuser with
'/usr/share/elasticsearch/bin/elasticsearch-reset-password -u elastic'.
Generate an enrollment token for Kibana instances with
 '/usr/share/elasticsearch/bin/elasticsearch-create-enrollment-token -s kibana'.
Generate an enrollment token for Elasticsearch nodes with
'/usr/share/elasticsearch/bin/elasticsearch-create-enrollment-token -s node'.
### NOT starting on installation, please execute the following statements to configure elasticsearch service to start automatically using systemd
 sudo systemctl daemon-reload
 sudo systemctl enable elasticsearch.service
### You can start elasticsearch service by executing
 sudo systemctl start elasticsearch.service
Couldn't write '1' to 'vm/unprivileged_userfaultfd', ignoring: No such file or directory
[/usr/lib/tmpfiles.d/elasticsearch.conf:1] Line references path below legacy directory /var/run/, updating /var/run/elasticsearch → /run/elasticsearch; please update the tmpfiles.d/ drop-in file accordingly.
  Verifying        : elasticsearch-8.7.0-1.x86_64        1/1
Installed:
Complete!
